My M2.2280 Blue worked fine first time in my Acer XC-780 on Windows 10 64Bit.
Anyway, also installed the dashboard program and it says its best to run the trim option once a week but it does not seem to add the task to the Windows Task Scheduler.
Reading the Acrobat manual, it does not even show the scheduler option so that was of no help.
Does it work for anyone?
Many thanks
