Today I bought buy a SanDisk Ultra II 240 GB SSD .
But Sandisk Dashboard 1.2.0 gives error .
Performance and Tools sections is passive .
How can I fix it?
How can I fix it?
Hi Stanco,
Is your SSD connected through a SCSI card?
We had some issues with SCSI cards and that’s why we decided to disable some of the Dashboard functionality until those issues are fixed. If you connect your SSD through a SATA port, the Dashboard should be fully finctional.
We expect to support SCSI ports in one of our next releases.
Thank you for reply georgealon,
I solved the problem.
I updated the Nvidia chipset driver, restart the computer .
The application worked.
