Speed of the USB Drive
I have Sandisk 3.0 Usb. It only gives 10 to 13 MB/s transfer speed when I copy items from PC to USB. Is it normal or something wrong?
Hi @sandiskspam
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
Ok, thanks.
Transfer speeds of 10 to 13 MB/s for your SanDisk USB 3.0 drive are below the norm, as these drives usually reach speeds of 100 MB/s or more. Check if you’re using a USB 3.0 port and try transferring larger files, as smaller ones can slow things down. Additionally, consider running a health check on the drive and ensuring it’s formatted with exFAT or NTFS for optimal performance. I’ve always been a fan of horse racing, but finding horse racing not on Gamstop was a bit challenging until I discovered https://nongamstopbetting.info/sports/horse-racing-non-on-gamstop/ They’ve reviewed all the top horse racing platforms outside Gamstop, making it easier to choose where to place my bets. The site’s thorough reviews were super helpful in guiding my decision.
Are you still here?
