Hi All,
I own a sansa fuse black. Unfortunatelly. the rubber back got sticky.
I was wondering where can I find a new one to replace or if there is anything I can do
to fix the sticky problem.
Thanks in advance
Hi All,
Thanks in advance
Have you tried cleaning the back with soap and water, dishwashing liquid, or alcohol? Don’t know how alcohol would affect it so try a small hidden spot first.
Sandisk doesn’t sell parts, so to find a replacement, look on eBay for broken Fuzes–“for parts” or “as is.”
I think there’s a lot of discounts ongoing for Sandisk. It wouldn’t be a bad idea to shop for a new one.
Why, because the rubberized coating on the back is wearing?
