Sound stutters
hi,
did anyone come across this?
while shuffeling thtough all my songs(~600 flac + 320’s) every other song the sound stutters like on an old sony diskman if u rocked it a little.
only thing i could think of is that the my sd card is 64 gigs class 10 sdxc.
hope its not the issue. no tag problems or any other strange  phenomenons occur.
data refresh  is quick.
thanks.
update:
found an old 32GB class 4 card…hope this will solve it…will update
update:
seems like the class 4 card solved the issue. thanks :slight_smile:
I do blame Sandisk for not warning people that they need to use a class 4 or slower card with the Clip+, Clip Zip, Fuze, and Clip Sport.
