I’ve tried to find answers in previous topics, but I’m not very good in dealing with problems which occurs to drive. I have this external HDD for a while and it worked pretty nice, but as it filled up it become more slower which is normal I guess. However later I started experience that time to time it’s stops responding during file transfers or just during safe ejection. It also failed few times to be detected by my PC. Moreover it failed to copy some bigger files from it to my PC, I guess they were corrupted.
I have read previous topics and ran some test. I hope it’ll tell You guys more, cause as I mentioned I’m not very good in understanding this stuff.
WD’s Lifeguard tool came up with these results:
SMART Status: PASS
Test Result: FAIL
Test Error Code: 08-Error was detected while repairing bad sectors.
I also ran Short Self-Test on GSmartControl and it came up with message “Compleate with read failure”
GSmartControl output log:
=== START OF INFORMATION SECTION ===
Model Family: Western Digital My Passport Essential SE (USB, Adv. Format)
Device Model: WDC WD10TMVW-11ZSMS1
Serial Number: WD-WX21A41Z0593
LU WWN Device Id: 5 0014ee 2b09d94af
Firmware Version: 01.01A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Sat Jul 27 10:37:19 2013 FLEDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: (24000) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 233) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 181 160 021 Pre-fail Always - 3950
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 452
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 361
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 259
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 110
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2600
194 Temperature_Celsius 0x0022 115 104 000 Old_age Always - 35
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 11
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Short offline Completed: read failure 90% 361 1499752856
2 Short offline Completed: read failure 90% 360 1499752856
3 Extended offline Completed: read failure 90% 358 1559046640
4 Short offline Completed: read failure 90% 358 1559046640
5 Extended offline Completed: read failure 90% 358 1559046640
6 Extended offline Completed: read failure 90% 357 1559046640
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
