Recently I’ve discovered that my external HD is performing very slow. I’ve used the WD utilities to do the 3 tests and besides the Quick one, the last two failed. I managed to transfer the data to another HD and I formated it and runed the tests again. Somehow, first time it passes the first 2 and fails the third one and if I do them again, it fails the last two. After this I downloaded the WD Data Lifeguard Diagnostics and these are the results:
| Test Option: | QUICK TEST |
| Model Number: | WD My Passport 0748 |
| Unit Serial Number: | ++++++++++ |
| Firmware Number: | ++++++++++ |
| Capacity: | 2000.37 GB |
| SMART Status: | PASS |
| Test Result: | PASS |
| Test Time: | 12:50:46, February 07, 2014 |
| Test Option: | EXTENDED TEST |
| Unit Serial Number: | +++++++++++ |
| Firmware Number: | +++++++++++ |
| Test Result: | FAIL |
| Test Error Code: | 08-Error was detected while repairing bad sectors. |
| Test Time: |
22:06:09, February 07, 2014
Any sugestions?
Thank you!
