Hi, I am using WD My Passport Ultra 2TB metalic hard drive. OS on my system is Windows 7.
Windows is recognizing the drive but unable to open or show its properties. As soon as I connected the drive to system it is asking to format. when I tried to format(which I don’t want to), formatting failed. I ran the diagnostic tests using Data Lifeguard Diagnostic for Windows downloaded from WD website and the tests failed.I tried to mount this on a linux machine and mounting also failed.Is there any way to find the issue with the drive and recover it without loss of data?
Following is the results of the diagnostic tests:
Test Option: QUICK TEST
Model Number: WD My Passport 0820
Unit Serial Number: [[DELETED - Privacy]]
Firmware Number: 1012
Capacity: 2000.37 GB
SMART Status: FAIL
Test Result: FAIL
Test Error Code: 06-Quick Test on drive 2 did not complete! Status code = 04 (Unknown failed test element), Failure Checkpoint = 96 (Unknown Test) SMART self-test did not complete on drive 2!
Test Time: 05:22:38, August 26, 2016
Test Option: EXTENDED TEST
SMART Status: FAIL
Test Result: FAIL
Test Error Code: 08-Unable to repair bad sectors.
Test Time: 12:18:27, August 26, 2016
Hi Pranav_G,
Same problem here. It seems this slow response is a general issue with WD external USB drive.
See this explanation for instance.
My Data Lifeguard Diagnostics failure report is reproduced below.
SMART Status: FAIL
Test Result: FAIL
SMART Status: FAIL
Test Result: FAIL
For unknown reason, with time, WD external HD controller becomes flooded with health data regarding potential bad sectors and the device goes into coma-like conditions.
This is a very WD specific behavior and, apparently, nothing to do.
