Sn8100 - no hardware encryption - w10
Unable to use hardware encryption for SN8100 2tb - w10. Latest firmware. Latest UEFI (MSI x870 tomahawk).
Forcing it by gpedit.msc will not provide expected result. It will be encrypted only in software mode.
for cmd: manage-bde.exe -status c:
result: Encryption Method: XTS-AES 128
ps. Please do not suggest I need “upgrade” to W11 →
“A security researcher says Microsoft secretly built a backdoor into BitLocker, releases an exploit to prove it”
"The researcher explained that they “just can’t come up with an explanation beside the fact that this was intentional. Also for whatever reason, only windows 11 (+Server 2022/2025) are affect, windows 10 is not.”
Hi @kaszpires
(Get Support for Your SSDs and Flash Products | Sandisk)
If not, contact Sandisk Technical Support for assistance.
(Contact Support | Sandisk)
Tried few times.
Result:
Basically - after long months - ZERO help / explanation / solution from SanDisk regarding inability of using Hardware Encryption on one of the Flag NVME…
Not surprise entirely but is it shameful and silly for Corporation of that size and potential in hardware / software engeneering.
It is much more ridiculous that there are problems with… Reporting problems using their own website / forms…
Hardware encryption is enabled by default. It is transparent to the OS. The idea is that each drive ships with a unique encryption key and your data is transparently encrypted and decrypted with this key. When you set a password, this key is encrypted and the original key is discarded. The only way to recover your data is to decrypt the encrypted key with the correct password. It is done this way because, if anyone were to access the NAND flash directly, all they would see would be gibberish.
