OS: Windows 11
SSD: 1 TB SanDisk Extreme Portable SSD
Sometimes when I make a copy of a file (or a folder) to the Portable SSD, the copy action doesn’t start immediately. It starts about 10 seconds later. Once it starts, the copy process is fast. I turned off anti-virus but it made no difference.
Have you opened a Support Case? If not opened, for more information, please contact the SD Technical Support team for best assistance and troubleshooting: https://kb.sandisk.com/app/ask
If you’re experiencing a slow start when copying files to a SanDisk Portable SSD, it could be due to various factors such as the file size, system resources, or the overall speed of the source drive. Consider checking the system’s performance, optimizing the source drive, or using a different USB port to improve the copying speed.
Have you considered using a data recovery tool such as EaseUS to retrieve any lost files? It could be worth trying if you haven’t already. EaseUS is both user-friendly and effective, making it a valuable option. Here’s the link to get started: SanDisk Extreme SSD Failure: Tips to Prevent from Further Damage
