I use my Fuze as a car stereo, but its power management drives me crazy!
When the exernal power shuts off, the Fuze actually starts up!
This makes for a convoluted exit from the car when you arrive at your destination – if you shut down the Fuze, it will only start up again. The best work-around is to unplug the power, then shut it down, to avoid its deciding to turn on again unexpectedly.
Even worse, if you’re listening to the radio, you might not notice the Fuze starting up. Then it runs out its battery while you’re out of the car.
Other players I used came closer to having this right. I’m not saying make everyone live with my preference (shutdown the Fuze when external power is removed), but it would be nice if the option to do this could be added to its settings.
