If the Fuze is in the car, connected to USB charger, it will turn on when the ignition key is turned, Will it automatically turn off when the car is trurned off or will it keep playing until the battery dies?
Why don’t you try it and tell us?
It will turn off only if you have your Sleep Timer option engaged.
Thanks for the two responses.
The first response was appropiate based on the way I worded the question. I already knew that it did not turn off when external power was removed. I was looking for a way to make it turn off.
The second response was what I needed. Now it turns itself off 10 minutes after removing external power. I would not have known this from the information in the user manual.
Thanks again
If it turns off after 10 mins, definitely, that’s the sleep timer. ![]()
