Every time I boot up my Win 7 PC I get the subject error and research shows this error is associated to my WD My Passport Essential 500 GB external USB connected drive. If I go to properties for the WD device it states the device cannot be used with ReadyBoost.
I am OK with the device not ReadyBoost capable but Microsoft does not have a solution to stop the persistant error.
Has anyone else seen this issue and if so resolved it? I am running Win 7 Ultimate 64-bit.
Thanks
you don’t still get the error when the drive is not connected do you?
Yes. The drive is connected 24/7. The error will occur at PC startup because the device is not a ready boot device, which is OK but I would like the error to stop. I could probably unplug the drive before PC startup and then plug it in to see if the error stops but that leaves room for forgetfullness.
Sorry, I did not answer you question specifically. If the drive is not plugged in I do not get an error.
