Hello I figured out my problem. The data is still on my External hardrive I just need to recover it. I can pay someone to recover it or buy the software but free is better. Thanks
Hello SFelts,
Please refer to the following link for Data recovery software’s option available to recover your data:
If software data recovery fails you can contact our third party data recovery companies:
Hi SFelts,
There are many companies which provide a trial version of data recovery software and allows to recover 1 GB to 2 GB data for free. However, it has the certain limitation of software like specific file type, size of data etc.
So, Download a top rated data recovery software from the official website of data recovery provider like ease us, stellar, Recuva etc. Install it on your system and run it. After scanning your system completely, the software will show you the files which it can recover. If you can find your data during the scan, then you need to buy the licensed software to restore the files.
Hey SFelts,
You can give Stellar Phoenix Windows Data Recovery-Free edition a try.
As I know, EaseUS data recovery can show free solution to you. However, to recover data in a professional way, Joyoshare iPhone Data Recovery is as well a nice choice, which can even convert HEIC to JPG and recover more than 20+ kinds of data.
There are various paid data recovery software available, some of which offer free or trial versions. These tools can assist you in scanning your external hard drive for lost data, but before using them, make sure to read the terms and conditions carefully. Free versions of the software may have limitations on the functionality or amount of data that can be recovered.
You can recover data using free data recovery software, which allows you to recover up to 1GB of data for free. Download the software, connect your external hard drive, and run a deep scan to locate and recover your files. Ensure you save recovered data to a different drive to avoid overwriting.
Consider losing crucial files on your external hard drive due to an unforeseen error, mistaken formatting, or accidental deletion. Although you may be stressed, there is a way to help you recover files on the HDD. The EaseUS Data Recovery Wizard is a strong and trustworthy solution for such issues.
These are the tools that data recovery professionals use:
https://www.hddoracle.com/viewtopic.php?f=36&t=3208
Many are cheaper than spammy second tier tools that hog Google’s search rankings.
The free version of DMDE can do a lot. R-Photo is completely free, but it only recovers photos, videos and audio.
If I remember correctly, TestDisk / PhotoRec (Windows/Mac/Linux) is open-source and 100% free to use. Because it relies on a text-based interface, it does have a slight learning curve.
If you use it, remember never to download or install the software directly onto the external hard drive, as this can overwrite the data you are trying to save. Instead, download it to your internal computer drive. If the text interface feels too complex, there are other user-friendly options available that also support deep scanning. [Read also: How to recover lost / deleted data from WD external hard drive ]
