Data Recovery
Hello everyone, My problem is that after having stored my data in the disk I can not access my data, indeed the disk is recognized by the PC but it does not give me the window to write my password. The data are very important to me and and I want to recover them . I have “My Passport Ultra” Hard Disk
Please contact the Data recovery partner to get the data recovered:
Hi Fadwa123,
Data loss is a stressful experience that affects most people who live a digital lifestyle. So, I have also faced the same situation which you are facing. So not to worry, I suggest a way out. Here I’m sharing some software names that you can use to recover your data from any external drives. I have explored EaseUs, Wondershare, Stellar Data Recovery, and Tenor. Out of these, I used Stellar Data Recovery software to recover my data, and to be very honest, it worked perfectly, and I recovered all required data with ease. It provides an option to select the drive you want to scan and recover the data. It’s not costly and easy to use. If you still face some issues using it, you can refer to their YouTube channel. I hope you got your answer. If you encounter some issue using Stellar Software, just drop a comment tagging me. I’ll guide you. Thanks.
Losing important files can be really frustrating, but don’t worry, there’s still hope for recovery. Have you considered reaching out to a professional data recovery service? A friend of mine had the same problem, but he went to a similar company, nwitservices.com. Maybe they can help you recover your files safely and efficiently. In the meantime, it’s important that you don’t attempt to access the disk yourself as this could cause further damage and make it harder to recover your data. It’s best to leave it to the professionals.
I have used Stellar Data Recovery software . Particularly for new users, the UI is incredibly simple to use. It recovers data with a high degree of success. It’s among the greatest data recovery programmes available for the price. The business provides live chat, email, and phone customer assistance! Also, customers may obtain excellent online informative resources from them. Installing it is really simple. Since we occasionally don’t want to restore all of the files, we prefer that we may see the preview of the files before choosing what to recover.
First, ensure that the connections between the hard disk and your PC are secure. If the problem persists, consider troubleshooting steps such as checking for driver updates, trying different USB ports, or using the disk on another computer to see if the issue persists. If these steps don’t resolve the problem, opting for professional data recovery software may be necessary to recover your important data.
First of all, make sure that the disk is properly connected to the PC. Or, you can try connecting the disk to a different USB port or another computer to rule out a port or PC-specific issue.
In Disk Management, make sure your drive has a letter assigned. If not, right-click the drive and select Change Drive Letter and Paths, then click Add and assign a drive letter. Then, update your disk driver by Device Manager.
Here are some basic solutions. If all else fails, then free data recovery software could be a good option. Please note that many free data recovery tools have limitations. They often only allow you to recover a certain number of files. I have listed some data recovery software worth trying in 2024.
  • Recuva (Unlimited free data recovery software, only for Windows)
  • 4DDiG Data Recovery (User-friendly, 24/7 support, 2GB free limit)
  • Disk Drill (Fast scanning speed, more advanced features, 500MB free limit)
  • TestDisk (Open-source, not suitable for beginners)
  • DMDE Free Edition (Professional, 4000 files limit)
  • EaseUS Data Recovery (Easy to navigate, over 10 yeares, 2GB free limit)
  • Wondershare Recoverit (Ehanced video recovery, 1GB free limit)
If you have lost essential files, there are numerous options for recovering them. Begin by examining the Recycle Bin on Windows or the Trash on Mac, where recently deleted data can frequently be located and recovered. Use Windows Backup (Settings > Update & Security > Backup) or Mac Time Machine (Apple > System Preferences > Time Machine) to restore files from a previous backup point.
If there are no backups, try BLR Data Recovery Tool (Windows) will help you recover erased files from internal and external devices.
Also available on: Data Recovery Tool
These are the tools that data recovery professionals use:
https://www.hddoracle.com/viewtopic.php?f=36&t=3208
Many are cheaper than the highly advertised second tier tools that feature at the top of Google’s search rankings.
“BLR Data Recovery Tool” is just a rebadged version of EaseUS (a second tier tool).
Before changing anything on the drive, I’d check Disk Management and see whether Windows is detecting the drive with its full capacity.
If the drive is detected normally but the files are inaccessible, EaseUS data recovery wizard could be used to check whether the files are still detectable and previewable. Anything recovered should be saved to a separate drive.
If the issue is actually related to a password or encryption rather than deleted/corrupted files, I’d handle that separately rather than assuming recovery software can unlock the drive.
