Sd card sandisk very hot in 30 minute
And corupted 8 sd card reader what ido
Hi @Milad7171
(Get Support for Your SSDs and Flash Products | SanDisk)
(Contact Support | SanDisk)
SD card getting corrupt is not new and dealing with a corrupted SD card can be hectic. I believe the overheating issue could be longer use or damaged connectors.
Remove the SD card and clean the slots, also stop using the card immediately, as overheating could lead to data corruption or damage.
As a solution, you may need to format your sd card as its fixes almost all the corruption related issues. But, I would recommend some manual solutions to fix your SD card before formatting. Check this article to know some possible solutions to fix the card: How to Recover Photos from a Corrupted SD Card?
You should also be vigilant about data loss scenarios that can arise due to a corrupt SD card.
