SD Card Experts.........Please Help Me Be Able To Protect Data on an SD Card From Being Copied
I am hoping to find someone that can help me copy protect data stored on an SD card. Is there a way to do this???
I have created some maps and would like to give them to a few friends but don’t want the data on them to be reproduced or copied.
I contacted a manufacturer of data cards and they said they could write data to a card for me that was copy protected but the minimum order was 5000+ units…ugh!!!
Please give me some help.
Depends on what format the files are (.pdf, .jpg, etc.). You’ll have to make the files read-only from whatever program created them, if possible. If not, maybe change the format to one that can be made read-only.
:smiley:   Hi Resq91,
Dear member of SanDisk Community, welcome.
Well, sorry for the delay, but it is a very specific topic.
Give the information as the theme works, but does not depend on users, if not of companies (trade secrets and restricted licenses).
CPRM     (Content Protection for recorded media)
All SD cards have copyright protection for SD standard data types.
T his enables commercial distributors to put music or other media on the device so that it’s protected from illegal copying.
The technology behind this SD card feature is called Content Protection for Recordable Media (CPRM).
CPRM was developed by the 4C Entity, LCC, the organization handling copyright protection licensing for IBM, Intel, and SD co-founders Panasonic and Toshiba.
4C Entity also developed the related technology Content Protection for Pre-recorded Media (CPPM), which relates to the DVD-Audio format for music.
CPRM and CPPM are generally associated with flash and DVD media formats.
CPRM doesn’t apply automatically just because you’re using an SD card.
In order for data to be protected with CPRM , the device that’s writing the data must first create a Media Identifier and Media Key Block (MKB) on the SD card.
The Media Identifier and MKB are written to a physical portion of the SD card known as the Protected Area.
Data stored in the Protected Area , is inaccessible through the SD card’s file system, but any CPRM-enabled device reading the SD card can use it for content protection operations.
To protect data with CPRM, a device uses the Media Identifier and MKB to encode the data as it’s written to the SD card.
To read the data, a CPRM-enabled device accesses the Media Identify and MKB and uses them to decrypt the data as it’s read from the SD card.
Therefore, even if you copy the CPRM-protected files from the SD card’s file system, you won’t be able to read them outside of that SD card.
Luck.
Regards, Alfred.                                                            (Google translated)
I know this is an old post but have decided to try this again. (Create these Maps on SD Cards)
I still have not found a way to save my map files to SD Cards in a way they cant be copied.
I see the Card has copy protection built in but how to I write the Media Identifier and Media Key Block to it??
Is there software I need for this?
The map files are in a .at5 format for use in Depth Finders for Navigation and Fishing.
Thanks for your help, I am no IT expert and could really use a hand/advice.
