The disk is write protected SD card
I’ve been using a SanDisk SD card with my Canon camera for quite a while, and it has always worked fine. However, when I recently tried to format it on my Windows laptop, I got this error message:
“The disk is write protected.”
I’ve already checked the physical write protection switch on the card — it’s definitely in the unlocked position. Could the card have become corrupted? Is there any way to remove the write protection or fix this?
@KrisWuuu
(Get Support for Your SSDs and Flash Products | Sandisk)
Try this one
(Contact Support | Sandisk)
You can easily remove the write-protection from the SD card using the Diskpart command, Windows Registry Editor or Group Policy. Read this article to learn how to remove Write Protection from an SD card without losing data.
Sometimes the issue is with the reader, not the card. If the reader is old or faulty, it might falsely detect write protection. Testing it on another PC or with a different reader. Then, let us know how it goes.
If your SD card shows a “write protected” error and the lock switch is off, try using diskpart to clear the read-only status. If that doesn’t work, use SD Card Formatter. Test the card in a different reader or device. If it still fails, the card is likely damaged and should be replaced.
In your case, you may take the following steps:
  1. Run Command Prompt to remove read-only attributes
  2. Edit Windows Registry (be cautious with every step)
  3. Repair the corrupted file system with the Windows built-in tool
  4. Recover all important data from the Sandisk SD card and then reformat it
Related how-to guide: How to Remove Write Protection from an SD Card
