I know the box says win xp min req, but unfortunately im stuck with my parents and windows 98… is their anyways to make it work with this os
nevermind i figured it out, all i had to do was switch the usb mode to msc and manually tranfers the files to the music folder (which is hidden btw)
Yeh, MSC is a good mode that enables it to work via drag and drop on basically any OS there is
