And there is a mini-boom of audiophile vinyl, a lot of it on 45-RPM. And most of the buyers of this vinyl probably want to be able to listen to their personal 24-bit digital copies on their portable players.
And there’s no way that the Cloud will be able to stream these massive files, at least with 3G, so for now, Sandisk, start cranking out those 64 GB+ SD-cards, along with your new portable player!
i was goign to say ROCKBOX it man because that will play 24bit FLAC and Gapless too.
big fan of the 180gram vinyl 24-96 rips out there. this is the best thing to happen to digital music.
sansa - get crackin and make a 24/96 gapless firmware - you’ll own this market when the audiophiles take note and start spreading the word. repackage/rebrand it as he HD AUDIO FUZE. work with the rockbox folk and use rockbox as the underlying OS and slap a sansa theme on there.
180 gram vinyl is quality material, but most of the 180 releases are simply the CD or digital masters on a vinyl format. That doesn’t sound good especially for vinyl.
However, analog masters on the 180 gram vinyl is great.
I’m sitty pretty now…I’ve got a brand new 8gb Sansa Fuze, V2–and Rockbox installed without any problems in about 5 minutes.
So with a 16 gb card, I can load about 25-30 albums or so–15 on the card, and the remainder in the internal memory. Not too shabby, considering that the cuts are ripped from fine turntables with high-quality vinyl. The Fuze with Rockbox does downconvert the 24 bit sounds during playback but the music still kicks ass–it rocks a lot harder that if had been taken from a CD.
Still waiting for the “HD” version of the Fuze–let see, 64 GB internal memory, can play the 24-bit 96KHZ Flac in its native format, can handle the new 64 GB micro sd cards, and eventually will be able to play the 1TB cards. Now maybe that could hold my entire vinyl collection in 24-bit/96 KHZ. A touch screen might be nice but I really enjoy the now-retro Fuze controls–I can change selections without looking at the screen, which is some situations, like being on a bike or care, can be useful.
Well, to all the 24-bit and vinyl detractors, I guess we’ll have to agree to disagree. I’m not as technical as a lot of you are, but I know that my ears can appreciate the difference between 16 and 24 bit, and it’s not placebo effect either. There’s just a much warmer and textured sound with 24-bit, for lack of a more technical explanation.
It sounds like you are listening to 16 and 24 bit tracks from different sources, which would contribute to the differences you are hearing too. I could make a 16-bit copy of my original 8-track and then compare it to a 24-bit copy of the original analog source and of course they would sound different.
To make a true comparison, I would try this:
Take the 24-bit track that you like so much, and downconvert it to 16-bit
Put both tracks on your newly rockboxed Sansa
Have a friend change the track names to “A” and “B” without telling you which is which
Do a blind comparison (without cheating and looking at the track info if your rockbox theme shows it) and see if you can really tell which one is 24-bit
If you can tell and like the 24-bit version better, more power to you! Go buy those big cards from Sandisk! I’ve lost enough of my hearing already that I’m sure I couldn’t tell, and I’d rather carry more music with me than get the best quality. I’m usually listening to my Fuze on the train with $100 Sony earbuds anyway. But you do what you want to do with your player, and have fun.
16-bits means that there are ~64,000 steps on the sine wave. 24-bits means that are ~16 million steps on that sine wave.
You might divide either of those in half if the highest bit is used for another reason. Either way, the resolution is significantly higher going from 16 bits to 24 bits (actually in the order of 256X).
This has nothing to do with frequency response, it has to do with the resolution, or smoothness, of the sine wave (and to some extent dynamic range). The dynamic range can be expanded (with the same resolution) if using higher bits. Hence, I’m not surprised when someone says that a 24-bit file sounds “warmer” than a 16-bit file.
A tube amplifier has a resolution of infinity. Its “warmth” comes from it being current-driven (a true sinusoidal power source for sound transducers [speakers]) and the characteristic of a “soft-clip.”
A larger dynamic range means more dynamic headroom and less clipping. Digital clipping can rob CD music of its warmth. Also, “edginess” of the sine wave can cause that “tinny” sound of CDs. You can use all the filtering you want to clean the edges. But the more you filter, the duller the music sounds (less presence). Either case, it is digital processing which causes the artifacts that can make digital music sound unnatural.
Your eardrums have a resolution of infinity (in its frequency range). That means any slight change due to digital-processing might be detected (if hearing loss hasn’t set in).
It is an age-old claim of audiophiles – that analog sound can never be reproduced. That’s why every audiophile equipment is call high-fidelity, not true-fidelity.
No offense, but you should really look things up, not just guess if you aren’t sure. It has nothing to do with the “smoothness” of the signal. An 8, 16 and 24 bit DAC all produce equally smooth outputs since “smoothness” is a property of the frequency range of the signal and nothing else.
More bits increases the maximum possible dynamic range, nothing more, nothing less.
Warmer == “I listened to two different mastering of the same song and didn’t realize it” == “I’m a noob, ignore what I think about audio”
This isn’t even wrong since it doesn’t say anything, its just gibberish.
Your eardrums have a resolution of infinity (in its frequency range). That means any slight change due to digital-processing might be detected (if hearing loss hasn't set in).
It is an age-old claim of audiophiles -- that analog sound can never be reproduced. That's why every audiophile equipment is call high-fidelity, not true-fidelity.
how are you even less informed then the person you quoted?
I beg to differ. The number of bits of a DAC has everything to do with the resolution of its output.
Which is why I said this:
" It has nothing to do with the “smoothness” of the signal. An 8, 16 and 24 bit DAC all produce equally smooth outputs since “smoothness” is a property of the frequency range of the signal and nothing else."
Looking back at your first post I see that you confused smoothness and resolution, so I should also have corrected you on that point. I’ll do so now. They are not the same. DACs of all resolutions have equal smoothness at a given maximum (e.g. cutoff) frequency.
I hope thats more clear to you.
ggin1 wrote:
The frequency response has to do with the bit rate, i.e. 96kbps.
In correct. Look up bitrate and frequency response. it’ll help you understand the difference.
ggin1 wrote:
Warmth, of course, is ultimately subjective.
Its meaning is also then subjective. Which means it doesn’t mean anything at all. For a word to have meaning it must be standardized and agreed to by both parties. Warmth is usually just something people say when they’re too lazy or uninformed to figure out what they actually mean to say. Used correctly, warmth is usually understood to mean something like a mild treble roll off and perhaps light harmonic distortion. But its seldom used correctly, least of all in this thread.
I can see you’re into double-speak. I thought going back to this forum might be fun. But, it’s not.
By the way, I’m a EE.
I’m a EE too, but what really helps is a background in computer engineering. Lots of EEs, especially older ones, didn’t learn this sort of stuff in school.
ggin1 wrote:
I’ve designed and repaired audio equipment.
And I helped write an audio driver the Fuze and Clip, so I know a thing or two about how DACs work You on the other hand obviously haven’t done any of the digital side, which is why you’re not familiar with the technical stuff.
What really helps is not being smug and condescending.
I’m not being smug. Actually since you just lectured me for about 10 paragraphs without having even the slightest clue what you’re talking about, I think I’ve been pretty nice. I did spend quite a few years learning how these things work
Honestly though, smug would have been “noob, go read wikipedia”. Condescending would be to point out that if you talk about things you’ve too lazy to understand, you’re either a liar or an fool. Instead I took the time to try and explain things to you. Shame you don’t care. Audio is pretty cool if your’e willing to spend the time to understand it.
ggin1 wrote:
I’ve designed various projects with DACs. No need to tell me how it works.
Designed projects with DACs, but obviously never looked at how they worked. Which isn’t your fault, they’re complicated, and you don’t have a background in digital or signal processing. But if you haven’t bothered to learn how stuff works, you shouldn’t be trying to tell people about them. Its dishonest.
ggin1 wrote:
I’ll just close by saying that good engineers enjoy their work and respect other’s works.
I guess your work in this case would be all the things you made up in this thread? Franky, I respect good honest work. Not empty posturing and dishonesty.
Bumping this b/c I’m curious if anyone knows how things have ‘advanced’ toward portable hi-rez “nirvana” – and seek your sagely advice as to what to get as my first attempt to have my 24/96 flac files from vinyl on my hip or in the car!
Seems like the sansa fuze v2 or clip + (?) – with Rockbox add-on – is our best bet . . . unless things have evoled since a couple of years ago when this thread last died.
Can someone advise. I like the idea of NOT spending a lot for a musicman or Cowan if I don’t NEED to . . . these little devices are inevitably stolen or lost or broken or stolen or lost :) . . . so “cheap” is the way to go . . . I only ever had a coby MP3 and used it until I realized where my headaches were coming from ! And then it was STOLEN out of my car, anyway! True story.
Right now, I’m recording in real time to my ZOOM 1 recorder which plays 24/96 but not flac, only its own proprietary “zoom” files. A bit of a PITA, but the sound is really sweet. If anyone knows a way to work around ZOOM’s software and get the thing to play FLAC files PLEASE LET ME KNOW. I will reward you! Bear hugs, good vibes, maybe more! BUt the Zoom has virtually NO UI . . . .you just have to push a button to move from “file” to “file.” Again, a huge PITA. So, I’m jonesing for a nice 24/96 player.
Thanks for interesting discussions here. Hope to hear from you guys soon!
Currently Sandisk has discontinued the Fuze/Clip and replaced them with newer models, so no further changes will happen with the Sandisk firmware. In rockbox, I’ve been working on a higher quality resampler. This will allow you to play 96k file with comparable quality to 44.1k file (currently quality is quite a bit less due to poor resampling). Hopefully I’ll get this in soonish, although the chosing the right algorithm and then optimizing it is time consuming and i’m quite busy these days, so no promises.
However, a better solution would be to not record vinyl in 24/96. Vinyl has less then 16 bits worth of resolution (much less really), and 96k is completely pointless in general. So all you’re doing is bloating your file sizes for the sake of making your files hard to play on portable devices.
Your best bet would be to record at 44.1k (or perhaps 48k followed by a high quality resampler, ideally one better then I can manage on the limited processing power available on the sandisk players). This would maximize compatibility, greatly decrease file size, avoid the possibility of low quality resamplers on many portable devices, and result in no loss of audio quality. There is literally no downside.
