Hi, I’ve recently purchased FLAC 24bit 96kHz songs, and it seems that the clip+ is not able to read it at all. What is the highest setting I can get away for FLAC?
16-bit. You’re correct, 24-bit is not supported by Sansa mp3 players. For that, you could install Rockbox, 3rd-party firmware.
Hmm 1 good reason to go rockbox lol. Just did a brief ‘research’ and it seems rockbox is rather problematic. Not sure if it’s worth to take that risk…
Depends on how bad you want to use those 24-bit FLAC files. From what I’ve read, only dogs could hear the difference between those and the run-o-the-mill 16-bit ones.
Well, I’ve tried listening to them on my computer (DAC > Westone W3), and there are subtle differences. For one, the 24bit source sounds smoother, while the converted 16bit sounds a bit harder, slightly more accentuated. Does that mean I have ears of a dog? lol
Maybe . . .
:smileyvery-happy:
If you use Rockbox to enable playing 24bit FLAC on Clip+, the gain in quality due to higher 24bit format may be offset by inherent lower audio output quality of RB itself vs. the original firmware. The only way to find out would be to experiment. (There is disagreement about whether RB Clip+ audio quality is inferior to OF Clip+; my own experience is that RB audio output quality is indeed slightly lower-fidelity than OF on the Clip+, as a result I am sticking with OF for now.)
I was under the impression that Rockbox takes the 24 bit audio (FLAC) and down-converts it to 16 bit anyway, so if you are under the illusion that 24 bit sounds better (which I don’t believe for a second); it would be negated anyway during the down conversion process.
Seems like the common concensus is to forgo rockbox. Oh well, at least I still have my computer and mediamonkey =)
You get that impression? Ha…to each their own, I guess. Rockbox sounds equally to good to me on all my Sansas as the stock firmware. I personally wouldn’t run a Sansa on it’s own firmware, if there was a Rockbox alternative.
I would probably have tossed my Clips and Fuzes long ago if it weren’t for Rockbox.
Well, you did say rockbox most likely converted the 24kbit to 16kbit, which defeats the purpose of using the 24kbit as source file. So no point going rockbox to have it read a 24kbit file as 16kbit, in which the sotck firmware does that already =)
I would say “try it for yourself and see if you can hear a difference”. Some people (including myself) say they do hear a difference, others say they don’t. (Again, this might be related to headphones used as much as anything else.) Fortunately, RB has dual-boot functionality built-in, so comparing RB with OF is pretty easy to do, although it is not a true blind ABX comparison.
There are also other good reasons to use RB, aside from sound quality considerations. But ultimately, I seek the highest-quality/fidelity audio, even if it means tolerating moderate deficiencies in other aspects of a system, and my ears discern that OF is better quality audio (notwithstanding output frequency accuracy) than RB on Clip+, so I choose OF for now. YMMV.
Looks like I need to do more reading up on rockbox. I just realised I have a clip and a clip+. Perhaps I should rockbox my clip for starters.
The stock firmware will not play a 24bit file at all…you’d have to convert it to 16 bit beforehand. Rockbox at least will do it on the fly. But most people wii not hear any difference between 24 bit and 16 bit anyways. These 24 bit/96khz files you see people raving about…sometimes one album will take up an entire GB of space! So screw that, I say.
A lot of the 24/96 files people are raving about are from remastered sources; then they try to compare them to the original masters in 16 bit. That is not a fair comparison.
I have yet to read or experience any human being being able to distinguish between 24/96 and a normal 16 bit Flac (or wav, PCM) in clinical trials, providing the original source material was identical in both instances.
Basically, the 24/96 is a marketing ploy to get people to re-purchase material they already have. It’s the oldest marketing gimmick on earth. Trying to convince people that it has to be better because there are more “bits” there. Again, I have yet to see any data to support their claim.
But, if you want to shell out your hard earned money on something that “makes you feel better”; go right ahead…it’s your money, not mine.
Some 24bit material out there is free: Some of the sfuff on archive.org (live music recordings). That 24bit material is typically recorded at higher 24bit/192kHz, and so the 24bit FLACs are not just remastered from lower bitrate recordings.
I’ve heard some 24bit remastered commercially released stuff that maybe sounded better than 16bit PCM/WAV versions, but that could have been due to the remastering itself.
All else being equal, 24bit/192kHz stuff has potential to sound better than 16bit/44.1kHz stuff. But also we all know that some folks cannot hear bitrate-based sound quality differences other folks can, and things like headphones/speakers/etc. also have a big influence on discerning quality differences.
Few digital audio players can handle 24bit, so I always produce FLACs at 16bit anyway. The sound of 16bit FLACs, of material with inherently high quality on hi-fi player & headphones, is astounding enough for me. ![]()
http://wiki.hydrogenaudio.org/index.php?title=Lame_Compiles#High_quality:_HiFi.2C_home_or_quiet_listening.
Proof is in the pudding as they say. If anyone can show proof; not just " I think they sound better", concerning 24 bit FLAC files…e.g. actual clinical trials, I’m all ears. Until then, the 24bit vs. 16bit debate is nothing more than talk.
fuze_owner-GB, I am with you on this one.
Sandclip, please read http://theaudiocritic.com/plog/index.php?op=ViewArticle&articleId=4&blogId=1 and http://drewdaniels.com/audible.pdf.
Maybe the proof exists by ABX or similar trials, maybe not. But the lack of someone “showing proof” to a doubter does not mean the difference is not real.
The classical fallacy is along the lines of: “There is no scientific evidence of ____, therefore it does not exist.” Actualy, lack of scientific evidence may simply mean that the scientific evidence has not been produced, irrespective of whether the phenomenon in question is real or not. (Lack of scientific evidence does not DISPROVE the phenomenon.)
