ok so i just bought this thing yesterday
i went to use it for the first time today
i fully charged it and loaded it up with music as well as a micro sd card
at work i started to use it for the first time and a few songs later it shut down
i didnt get it to turn back on until a few minutes later i removed the sd card and reinstalled it and it turned back on
a few songs later it did the same thing
and the same trick turned it back on
a few songs later it did it again
and now it wont turn on whatsoever
i have tried holding the power button for thirty seconds and nothing
i connected it back to the pc i used to charge it and load it and sometimes it says driver install failed
or it will say i need to reformat the disc, sounds like a bad idea to me so i didnt reformat
then i downloaded the firmware update software and that wont recognize the player
now i work in a factory and today was like 85-90 degrees farenheit
and i had the volume at aproz 3/4
did i overheat it?
this thing had great reviews and i really liked it cuz of its size and folder browsing and sd slot
i think i will exchange it tomarrow at the store for an identical unit and hope that mine was defective cuz i like this products features alot
and tips?
i must say this experience was dissapointing to say the least and if the new unit does the same thing or if this simply cant take the heat i will just have to go with another brand and hopefully i can find one with the same features
i almost forgot
if it matters it is the 4gb model
and the sd card is a SanDisk micro sd hc 4gb
