Sansa Clip Sport Shuffle While On Repeat
When I have an album on shuffle and repeat it stops at the end of the album.
Playing it through memory card.
Any tips?
Am I missing something?
Does it repeat if you don’t have the shuffle turned on?
Yes
SET THE CLIP SPORT TO SHUFFLE ONE ALBUM CONTINUOUSLY FROM MUSIC OR CARD MENU
Try these selections in the Settings -> Music Options Menu
        Shuffle = On
        Repeat = All
Then, select MUSIC or CARD -> Albums -> Select Album.
Then select “Shuffle”, OR a song title.
Figured it out.
When Shuffle and Repeat is on.  That is fine.
I am pressing Shuffle on the album and that stops the Repeat for some reason.
I am on firmware 1.38 but the Shuffle on Repeat goes off whenever I start a new play. Its states Repeat Song is on but I have to press it again to work it. Please anyone?
