sansa clip+ 4gb memory
out of the box, my sansa clip+ only has 3.45 GB/ 3.66MB. thats almost 200mb gone? what this?
and also, I cant find where the preinstalled music is. I need to delete them.?
That’s all the “usuable” space you’re going to get on a 4GB unit. Some of it is taken up by firmware, RAM and protected operating files and then of course, there’s the math difference. 4GB in marketing or advertisiing speak is not the same as actual physical space.
To find and/or delete the pre-installed music/video samples, you must connect in MTP mode.
That’s all the “useable” space you’re going to get on a 4GB unit. Some of it is taken up by firmware, RAM and protected operating files and then of course, there’s the math difference. 4GB in marketing or advertising speak is not the same as actual physical space.
