SanDisk Wireless Stick Support Informaiton page
SanDisk Wireless Stick Support Information Page
Capacities: 16GB, 32GB, 64GB, 128GB
Fimrware Update
FW 4.0.0 (2034)
Downloads
Wireless Stick Getting Started Guide
Wireless Stick iOS User Manual
Wireless Stick Android User Manual
Limited warranty: USA-1 year
FAQs
  1. Wireless Stick Supported File Types
  2. Connecting to the Wireless Stick using iOS or Android devices
  3. Configuring Internet connection for Wireless Stick
  4. Using camera roll/Gallery backup in the Wireless Stick App
  5. Backup or restore your contacts using the Wireless Stick App
More SanDisk Wireless Stick Answers >>
Sir
I am having android 4.0 tablet.
Through wifi both devices are connecting , but I couldnot see the files in tablet.
Sandisk connect app couldnot loaded in the tablet, since it supports 4.2 and upwards only.
Any solution to use sandisk connect wireless with tablet with android 4.0 version
Laks
can you upgrade the tablet to 4.2?
You should be able to access it through your web browser. In the instruction booklet or even the documents here on SanDisk’s site should give you the generic web address for your device.
Transfer files between Wireless Stick and a device using a web browser
You can transfer files between Wireless Stick and any device with a web browser. This could be useful when a mobile app is not available for a specific platform or it is not possible to install the mobile app on shared devices. For computers this will allow multiple devices to connect wirelessly via a browser instead of a direct USB connection.
Not all features available in the mobile app are available via the web browser. Drag and drop file upload is supported in browsers that support drag and drop.
1 Connect to Wireless Stick Wi-Fi network “SanDisk Connect ######” a. ######willbeauniqueidentifierforyourspecificunit.
2 Enter www.sandisk.com/myconnect in your web browser
3 You can now browse & download files within the browser
Some browsers will automatically try to connect via HTTPS. If you see an HTTPS error, please connect via HTTP.
