http://www.sandisk.com/products/ssd/sata/ultra-plus/
SanDisk Ultra Plus Solid State Drive
Breathe Life Back Into Your Computer
The SanDisk Ultra Plus Solid State Drive (SSD) brings consistently fast data speeds, lower latency times, and reduced power consumption to your PC or laptop. Ideal for read-intensive applications like photo and video editors, this SSD boosts your computer’s performance from bootup to shutdown.
- Available in capacities up to 256GB
- Durable SSD design offers more reliable performance
- Lower power consumption and cooler operation than an HDD
- Ideal for photo editors, music-production software, and other multimedia applications
Upgrade Computer Performance with Fast Data Speeds
With its consistently high read speeds, the SanDisk Ultra Plus SSD is an ideal upgrade for an older PC. The 256GB and 128GB SSDs can achieve read speeds of up to 530MB/s, while the 64GB SSD offers speeds of up to 520MB/s. You’ll experience faster operating system bootup, quicker program loading, and improved response times when running memory-intensive multimedia applications.
Reliable Solid State Design Extends Your System’s Lifespan
Featuring reliable solid state architecture from a global leader in flash memory storage solutions, the SanDisk Ultra Plus SSD boasts a mean-time-before-failure (MTBF) of up to two million hours.** The drive features no mechanical parts to wear down and break, allowing it to store data much more reliably than a traditional hard-disk drive (HDD)** . The SSD is also designed to withstand shock, making it even more durable.
Low Power Consumption for Cooler, Quieter Operation
With its low-power architecture, the SanDisk Ultra Plus SSD places minimal strain on your system’s resources. The drive consumes less power and produces less heat than a traditional HDD, easing the burden on your PC’s power supply and cooling system. It also runs quietly, so you can enjoy videos and games without distracting background noise.
Generous Storage Capacity
Available in capacities up to 256GB, the SanDisk Ultra Plus SSD offers enough space to accommodate games, applications, and your operating system. It also provides ample room for backing up important data, including photo albums, videos, and personal documents.
Compatibility and Warranty Information
The SanDisk Ultra Plus Solid State Drive is compatible with SATA 6Gb/s interfaces and is backwards compatible with SATA 3Gb/s and SATA 1.5GB/s interfaces. It is backed by a three-year limited warranty.
- Available capacities: 64GB, 128GB, and 256GB
- Dimensions: 028 in. x 2.75 in. x 3.95 in. (7.0 mm x 69.85 mm x 100.5 mm)
- Operating temperature: -32ºF to 158ºF (0ºC to 70 ºC)
- Storage temperature: -67ºF to 203ºF (-55ºC to 85ºC)
- Interface: SATA Revision 3.0 (6 Gbit/s)
- Shock: Resistant up to 1500 G @ 0.5 m/sec
- Vibration (Operating/Non-operating) : 5 gRMS, 10-2000 Hz / 4.9 gRMS, 7-800Hz
- Power Consumption (active): 0.12w
- Support: Three-year limited warranty**
