I am considering using the following SSD in my PC build, however I heard there was compatibility issues so I’m wondering if my PC will be able to use it. This link will take you to my components list-
https://pcpartpicker.com/list/
Kind Regards.
when i clicked on the link the list was empty
Not sure why that was I followed it, it worked fine? Anyway try this-
http://pcpartpicker.com/list/Pc3GGf
I believe this will work, thanks.
im sure there are no compatibility issues with this motherboard that you intend to use along with the ssd
so go for it
Hi Badoirieboy,
There is not compatibility issue to my knowledge at this point for Ultra II SSD
