Hi everybody,
I bought an usb key Ultra Fit 128GB for my tablet.
I need to store files higher than 4Go then I formatted it in NTFS 4k.
With windows and linux, the writing speed doesn’t go above 10Mo/s and sometimes it stops to transfert …
I wanted to buy an Extreme Pro but I am afraid I’ll get the same speed problem since the benchmark of the Utlra Fit is very good.
I don’t trust Crystalmark benchmarks anymore. The usb key became useless for me, 10Mo/s is bull****, my internet bandwidth is higher than this.
Which system file am I supposed to use ?
Thank you.
