hi friends!,
My sandisk ultra is corrupted while using on my laptop, I have important data on it.
Please suggest me how can I retrive my data and fix this error in my Sandisk Ultra.
Hi @lolla ,
@lolla did you find any solution? I too am facing the same issuse any advice would be appreciated ![]()
Hey everyone! If you’re looking to transfer your playlists or songs between different music platforms like Spotify, Apple Music, Amazon Music, or YouTube Music, I highly recommend trying out Muzconvtool. It’s a versatile tool that simplifies the process and supports a wide range of music services. You can easily move your playlists without losing your favorite songs.
1.You can connect the SD card to a different computer or device.
2. Use Check Disk (Windows):
- Right-click on the SD card in “This PC.”
- Go to “Properties,” then the “Tools” tab, and click “Check” to fix any issues.
- If it’s still not working, try recovery programs like Stellar Data recovery, Recuva, Disk Drill, or PhotoRec to recover your files.
- Use Command Prompt:
- Open Command Prompt as an administrator.
- Type
chkdsk X: /f(replace “X” with your SD card’s letter) and hit Enter.
Have you recovered the lost files that mean a lot to you?
Reboot your computer and reconnect the SD card to check if it pops up under “This PC.” If it’s still missing, right-click the Start button (or press Windows + X) and open Disk Management to see if the computer detects the SD card at all.
Next, run the Windows built-in CHKDSK utility to scan and repair the card. It is great for scrubbing away minor glitches or logical errors.
If the files remain invisible, consider using a dedicated data recovery program to perform a thorough (deep) scan. Generally, if the files appear in the scan results, you are only one click away from restoring them. [This related blog also aligns with your needs: Recover SD Card: Memory Card Data Recovery Software and Fixes]
