Files deleted automatically from sdcard
I recently bought 64gb Ultra SdCard for my android phone. I put a folder in it with 300 mp3 files, after week, now the folder just disappeared. What is the reason behind it?
Hi @junomariop,
Please contact the SD Technical Support team for best assistance and troubleshooting:
https://kb.sandisk.com/app/ask/
In my view, the reasons for the issue may be:
#1. There are some logical errors with the SD card, such as bad sector. Try runnig CHKDSK to find and fix it.
#2. Since the lost data is mp3 file, you may try deleting the Nomedia file in the SD card to see if it works.
#3. Software errors. Check the apps which are installed after the mp3 files loss to see if it’s resulted from software conflict.
These are just common fixes. Hope they can help you out.
Check this link to get the details and more solutions.
Do you know that you can recover deleted or disappeared music/songs (mp3 files) from Android SD card with the help of most popular and amazing Android Data Recovery software.
However, there are other several ways to recover deleted music/songs from Android phone, the solutions can be found here - How To Recover Deleted Music/Songs From Android
Have you tried showing hidden files on your SD card? Sometimes folders can appear hidden due to settings or malware. Use a file manager app on your phone to check for hidden files.
In additionally, SD cards can experience file system errors that make folders or files inaccessible or disappear. If possible, back up any remaining data on the SD card and format it using your Android device. This can often resolve file system issues. Another possibility is that you might have purchased a low-quality or counterfeit SD card. If you want to recover lost files from an SD card, this source might be helpful.
Hi @junomariop,
Here are few new useful suggestions that you can try:
  1. Check for Hidden Files: Sometimes files or folders can become hidden. Use a file manager app to check for hidden files on your SD card.
  2. Run a Diagnostic Check: Use your computer to run a diagnostic check on your SD card. Tools like CHKDSK (Windows) or Disk Utility (Mac) can help identify and fix file system errors.
  3. Use Android Data Recovery Software: Your files have disappeared from SD card, so using a reliable data recovery tool can be very helpful. Stellar Data Recovery for Android is an excellent choice for this. It’s designed specifically for recovering lost or deleted data from Android devices. (Make sure to avoid using the SD card for any new data until you’ve attempted recovery. Adding new data can overwrite the lost files, making them harder to recover.)
One of the most common causes is corruption in the SD card. This can happen due to improper ejection, physical damage, or just wear and tear over time. Files or entire folders might disappear if parts of the card become unreadable. I would recommend checking out this blog to know how you can fix them.
There could be several reasons why your files or folders disappeared from the SD card. Here are some common ones:
  • Android OS updates
  • Bad sectors on your SD card
  • File system corruption
  • Malware infection or faulty apps
  • Low quality SD card
Check out this blog post to learn more about how to fix the files disappear from sd card error:
