Hi all…
i have a problem… i have some files on my Thumb Drive… i did not delete or move it anywhere else… and now it shows EMPTY!!
Disk capacity available is 16GB/16GB… where did my files go to??
im using mac OS… pls help!! thanks!
Hi all…
Hi Joelabu,
Dear member of SanDisk Community, welcome.
Please, try other ports on the Mac (maybe the flash drive, needs more power).
Also, can you try your Sandisk Ultra 3.0 of 16Gb, on a PC (win)?
And then you tell us, what happened.
Luck.
Regards, Alfred. (Google translated)
When you loaded files on this thumb drive, did you use a MAC or WIndows? I’d certainly check with a Windows PC first and see if it will yield with a different result. ![]()
