can i make this pen drive’s file format to NTFS system
You should be able to.
plz tell me how… n Is ntfs is faster den fat32
NTFS is not faster than FAT32. If it were then the vendor would have made them that way. Better performance = better price. ![]()
I think he wants it to be compatible with a specific system. You can use windows to do this for you. Open My Computer - Right Click on your USB stick drive and select format.
It should then give you which file format to set. FYI, this will delete all your files.
actually i hv bought dis sandisk ultra 16gb pen drive jst 2 days ago… bt wen i copy sumthng in it, only around 5mb/sec speed is attained… how it cn be increased?
