SanDisk Tool That Could Display Card Health Status
I just purchased a SanDisk Card Reader. Are there any tools or commands that could display the SanDisk Industrial 32GB microSD Card. I’m using Windows 7 and Windows 10 PC systems. Please advise. Thanks!
Kind Regards,
Viet
ChatGPT
To display the details of your SanDisk Industrial 32GB microSD card on Windows 7 or Windows 10, you can use built-in tools and commands:
  1. Disk Management:
  • Press Win + R, type diskmgmt.msc, and press Enter.
  • Locate your SanDisk microSD card in the list to view its details.
  1. Command Prompt:
  • Open Command Prompt as an administrator.
  • Type diskpart and press Enter.
  • Then type list disk and press Enter to see all connected disks.
  1. PowerShell:
  • Open PowerShell as an administrator.
  • Type Get-PhysicalDisk and press Enter to display detailed information about all physical disks.
  1. File Explorer:
  • Open File Explorer and go to This PC.
  • Locate your microSD card under Devices and Drives to see its basic information.
These methods should help you display and manage your SanDisk microSD card on both Windows 7 and Windows 10 systems.
The previous answer will help you find the manufacturer details of your external SD card. If you want to get a clear status on the drive’s health, third-party software like CrystalDiskInfo can provide more detailed S.M.A.R.T. data than built-in tools. These programs offer a user-friendly dashboard with reports, such as drive temperature, error rates, and a visual health indicator (e.g., “Good,” “Caution,” or “Bad”), and so on.
If you want to check the health status of your internal hard drive, you can follow these steps:
  1. Click the search icon on the taskbar and type “Command Prompt” in the search box.
  2. Right-click on Command Prompt and select “Run as administrator.”
  3. In the Command Prompt window, type the following command and press Enter:
    wmic
  4. Next, type the following command and press Enter to check the health of your SSD:
    diskdrive get status
Checking SSD Health on Windows:
  • If the status shows “OK,” it means your SSD is working normally (refer to the result in the above example image).
  • If it shows “Pred Fail,” this indicates your SSD may be failing, and it’s recommended to back up your data immediately to avoid potential data loss.
( Here is a related post on how to perform SSD health check on Windows and Mac. )
