Sandisk Problade Overheating
I’m having issues with my pro blade drives getting incredibly hot in the pro blade station. Since noticing this phenomenon, I have read about these drives failing due to to overheating- and am very worried that I will experience the same issue at some point. I spent a lot of money for this system and am a bit alarmed to hear nothing but silence from Sandisk.
The fans in my problade station only kick on at start up- after that they become quiet. Clearly something is happening in which the station is not adequately cooling the drives enough- because each pro blade becomes too hot to touch.
I am going to be contacting customer service about this- but it would be good if other people on this forum post the same issue.
Hi @ifilmcle ,
I had the same overheating issue recently after I got two more mags. Win11 OS + mags reformated to NTFS
The old mag has SN750E inside the enclosure, which runs NVMe X4 8GT/s (PCIe gen3), they are warm (around 40C) and the station is usually quiet and the fan runs occasionally at low speed.
The new mag has SN850XE inside the enclosure, which runs NVMe X4 16GT/s (PCIe gen4), the station fan runs frequently and lound. They’re much warmer and could burn your hand.
I’ve also experienced similar overheating issues. Using with Mac OS 14.4.1, the Pro-Blade Station fans will increase speeds until the device just over heats and shuts down. Its quite annoying and unexpected behavior when using the Pro-Blade Station to offload large amounts of video footage to these Pro-Blade drives. I thought the behavior was an isolated incident, but it happened multiple times during a 3 day shoot that generated 17.11TB of data, over the course of 3 days. The fan speed steadily ramps up, then shuts off, ejecting whatever Pro-Blade drives are mounted to the computer. I was also running an OWC Flex 8 RAID and X Camera Card, and those devices did NOT eject from the computer. So the behavior is isolated to the Pro-Blade Station.
I have the same issue with my new pro blade enclosure: the four mags are very HOT. Has anyone found a solution or the cause of this overheating?
After talking to customer support : apparently the operating temperature is supposed to be fairly high. What has helped me is plugging the enclosure directly into the wall outlet and not through a power strip. Also, it helps not to unmount the drives and leave them in the enclosure while it’s still running. So if the drive is unmounted and you still have the enclosure on- you have a much higher chance of cooking it. I don’t know why this is other than faulty design. This is a little infuriating given the price of these things. However, I have not had any serious issues since.
OK. Thanks for your info. I will leave two mags in now and only insert the rest when I need to use them.
Does anyone know if we can read the temperature readings from onboard sensors? That way I can adjust the location of enclosure on my desktop.
Honest I don’t know how you can imagine on it.
Material: Metal flash drives tend to get warmer while in use than other types of USB flash drives. This is simply because metal absorbs heat much more easily than materials like plastic or wood do . Size: Smaller flash drives often tend to get hotter because they concentrate more heat into a smaller surface area. :yum:
Overheating continues with the 4TB magazine when used in the Pro Blade Station. This magazine contains the WD_BLACK SN850XE module and during a 3TB copy failed repeatedly when the SanDisk Professional Pro-Blade Station shut down unceremoniously. I’ve moved it temporarily to the Transport which operates at 10GB on a Mac to complete the copy.
A firmware updater has been released for macOS.
