My sandisk flashdrive mini is not working with iphone it shows connect with device but when we connect into the iphone slot ixpand drive got open
Hi @Dang,
Speaking about the iXpand drive, it is a different product from the SanDisk flash drive mini. The iXpand drive is specifically made for use with iOS devices. It requires the use of the iXpand Drive app in order to work. If you are seeing the iXpand Drive app when you connect your flash drive to your iPhone, it means that your flash drive is not compatible with iOS devices.
