SanDisk Memory Zone 已停止工作
我在 Windows 10 24H2 26100.7462 安装 SanDisk Memory Zone 后,无法运行。
能看到启动 Logo,但不久后崩溃。
@HuaJingyu Windows 10 ARM64 is not supported.
( Get Support for Your SSDs and Flash Products | Sandisk )
Try this one.
Machine translate:
Hello.
My computer is not ARM, it’s x64.
In addition, after I installed the graphics card driver, the problem was resolved. (The software no longer crashes.)
So this issue only occurs when the graphics card driver is not installed.
I hope it can be fixed to support operating systems without the graphics card driver installed, because this software is used to manage SanDisk disks and does not require a graphics card driver.
Original text:
你好。
我的电脑不是 ARM,是 x64。
另外我在安装显卡驱动后,问题解决了。(软件不再崩溃。)
所以这个问题,只会在没安装显卡驱动程序时发生。
希望修复,以支持没有安装显卡驱动的操作系统。因为这个软件是用来管理 SanDisk 磁盘的,不需要使用显卡驱动程序。
