SanDisk® Media Manager PC software transports songs and photos from your PC to your SanDisk memory card for quick and easy use on your mobile phone.
This software automatically organizes any music and photos transferred to your card into the folders required by your phone for immediate playback.
With microSD™ reader
For the best user experience, follow the steps below
Download the Media Manager software
Launch SanDisk Media Manager.
Insert the microSD reader with microSD/microSDHC card into a USB port of your computer.
SanDisk Media Manager detects the SanDisk memory card.
You can now start using Media Manger to copy your songs and photos to and from the memory card.
Insert the card into your mobile phone. Refer to the mobile phone manual to locate the memory card slot on your mobile phone.
http://www.sandisk.com/microsites/mediamanager/index.html
- Launch SanDisk Media Manager.
- Insert the microSD reader with microSD/microSDHC card into a USB port of your computer.
- SanDisk Media Manager detects the SanDisk memory card.You can now start using Media Manger to copy your songs and photos to and from the memory card.
- Insert the card into your mobile phone.
- Refer to the mobile phone manual to locate the memory card slot on your mobile phone.
With mobile phone supplied USB cable:
- Insert the SanDisk microSD/microSDHC card in the mobile phone. Refer to the mobile phone manual to locate the memory card slot on your mobile phone.
- Change the mobile phone settings so the memory card is visible via USB connection. Refer to the mobile phone manual on how to make the memory card visible via USB connection or click here for online wizard.
- Connect the mobile phone to the PC using mobile phone supplied USB cable.
- You can now start using Media Manger to copy your songs and photos to and from the memory card.
Release Notes (version 1.0.1.8)
- A Red flash of the main window may appear when restoring the SanDisk Media Manager from a minimized state (Windows® 7 only).
- A slight lag may exist when scrolling through the photo list with many gigabytes of content loaded; this issue has been improved since the previous release but is still present.
- Running the SanDisk Media Manager while logged into Windows® as a “Guest” user is not supported.
- Certain virus detection programs may recognize the autorun.inf file that comes preloaded on the card as a threat. The threat can be ignored as the autorun.inf file has been confirmed to be safe and not infected.
- When the user selects “Fill my card” it informs the user, the size and that this could take up to “n” number of minutes to complete. Also a countdown timer of how much time remaining until completed once the transfer starts was added.
- The default position of sliders in the “more options” area of the selects “Fill my card” window for Photos/Music and Older/Newer are now in the middle.
- If the user has “hidden” any files, they will not be copied to the card when the user selects Fill My Card.
- Multiple issues in the phone profiles were corrected.
