I just purchased two new Sandisk flash drives which works perfectly on all other computers but mine.
The drives show up on my ocmputer but has 0 bytes, I can’t format or do anything on there. I’ve tried deleting certain registry files, rebooting, and so on…but nothing has worked so far.
It appears on device manager but not disk management so i can’t rename the drive either. Any idea how to fix this?
It’s possible a Windows Policy setting got changed, or some malware got on the machine, that’s causing the removable disk access problem. Sorry I can’t be more specific.
Already using admin profile. Other mass storage devices work (like my super cheap made in China 3usd ones)…just not sandisk. I think my computer just hates my new flash drives.
“I wish i could fix it with just a bandaid. Life would be so much easier.”
Ok, what’s different with your machine? Same brand/model as the others? Same USB devices as the others? Same antivirus as the others? Same version of Windows as the others?
All our computers are same model, same windows version, everything is the same. I’ve just ended up using my colleagues computers to save my files or drag them onto the shared server.
