SanDisk Extreme PRO USB 3.2 Solid State Flash Drive
what difference both but same model i don’t understand G and A
SDCZ880-1T00-G46 and SDCZ880-1T00-A46
Hi @gopala33
It’s simply a code for the country. There is no difference in Specification.
not opened case
i asking what country for G and A
i already ask contact they wont tell me country G and A daam
they said would like to know the difference between G and A on the SDCZ880 I TB.
Please be informed that the letters are just codes to show where the drives where manufactured for internal use only.
seen wont tell country for G and A
help guys
