Sadly, I think there’s non yet. Maybe the developers are still finding ways in order to make this happen. <img src=“https://imagicon.info/cat/5-43/1.gif”/>
I registered just to say thanks to cryppy for that link.
http://agnipulse.com/2012/03/filter-drivers-removable-media-fixed-disk-windows/
Finally I’ve turned my SanDisk Extreme 32 GB USB flash drive from removable in to a fixed drive. This is the way.
Karyonix’s – DiskMod 0.0.2.2 - diskmod.sys driver worked for me flawlessly. I could build a Windows To Go usb drive in minutes.
Thanks man!
You do realize that the drive will only appear to be Fixed on systems that have the diskmod.sys driver installed, right? On systems without the driver it will still be seen as Removable.
If you put Windows To Go on it does it boot?
Re: Sandisk Extreme 64GB - make it a fixed drive?[ New ]
03-08-2015 06:19 PM - edited 03-08-2015 06:23 PM
I leave my previous post for reference.
I own a 32 Gb SanDisk Extreme USB stick. After several tries, trying to make the usb stick boot with Windows To Go (I have been successfully able to make it fixed with diskmod.sys and created my WindowsToGo stick using Rufus), it failed every single time to boot, only once it showed signs that it would work using MBR partition thype in Rufus and not GPT, but it hanged for 3-4 hours and I rebooted my laptop eventually.
Then, I stumbled upon WinToUSB which has a different approach. It creates a VHD drive on the USB drive and not applying the install.wim with expanded folder structure as every other tool out there do. For the last approach to work one needs a real proper fxed drive. And that is not available for SanDisk Extreme usb drives as SanDisk had a change of heart (poor heart) and reverted all newer drives’ bit and therefore making them removable again and not fixed drives as they were sold once.
So, for anyone’s interest, I have tested Windows To Go using Windows 8.1 Pro on my 32 Gb San Disk Extreme created with WinToUsb and it works amazing.
Of course one could build the flash drive using the VHD method only using Diskpart.exe and imagex.exe, but it’s a pain in the ass. Takes much much longer and several reboots are needed for it to work.
So go on and try WinToUSb !!! Results guaranteed.
kukubau
An interesting update kukubau. Thanks.
Hi folks,
My main problem was not just to make the flash drive appear as a fixed disk but making a bootable Windows To Go device for Windows 10 Tech Preview on my Extreme SDCZ80-064G-GAM46 64GB stick.
After trying everything else possible from various instructions and tools found online, WinToUSB beta 2.1 finally worked for me on my SDCZ80-064G. Be sure to select the VHD installation mode (used a 14GB virtual disk setting). I tried WinToUSB version 2.0 without this new option and it didn’t work. After using v2.1 beta I am now able to run Windows Tech Preview from the Sandisk Extreme on my laptop. First boot to setup Windows TP was very slow but once loaded / configured, not so bad. Each boot using the WTG drive now takes several minutes but response is decent once it’s up and running.
This solution solved my issue. It looks like WinToUSB creates the boot partition (14GB size in my case) and that is marked as a Basic (fixed) disk but other drive partition still appears as Removeable Disk in Disk Management but that doesn’t matter to me. I only want to use it as a Windows To Go workspace. There may be a way to setup additional partitiions (Disk Management won’t let me shrink the volume while running WTG workspace) creating an unbootable partition to use for normal storage but I’ll let others figure that out… Fo rnow I happy having WTG working.
Good luck!
Updating my own post here: FYI, better to set the VHD to max size of your drive if you want most room in your WTG workspace. I have re-built my workspace to consume the entire availabel space (had to start over with WinToUSB). I think if you leave some space unallocated to the VHD, you can use that remaining space as normal flash storage either in the WTG workspace or indelendant of it. It will appear in Windows as removable drive.
Could you please post step-by-step guide on how to apply the diskmod.sys? I’m trying it with 64GB version and W8.1 64bit(and planning to use Rufus), but my last try resulted in bricked OS
Okay, bricked my other computer, Win8.1 64 bit too, just by installing the driver
Did you follow the install instructions on the link given?
Install and use diskmod.sys
Update: For Windows 7 64 bit you need to enable TESTSIGNING before installing Diskmod
Read more: http://agnipulse.com/2012/03/filter-drivers-removable-media-fixed-disk-windows/
Ah, it didn’t say ‘Windows 7 and later’, I’ll try again soon then
Used the testmode command and ran the .bat as admin, and got this error.
Solved it by partitioning the drive like this
I realized my error of not reading documentation, GPT obviously didn’t work. Created 60GB NTFS part under MBR and installing it atm, I assume that will work so thanks for help
All works, diskmod.sys is unnecessary , just use WinToUSB 2.1
It’s nice to see so many people saying “THANKS” to me after helping them out.
<sarcasm>
Thank you everyone so far for the guidance.
The following solution finally worked for me with a removable drive on both BIOS and UEFI :
Format the drive using Rufus 2.1 (Rufus adds a custom UEFI NTFS loader so that UEFI can boot from NTFS instead of FAT32)
- MBR partition scheme for BIOS or UEFI computers
- File system: NTFS
- Create a bootable disk using: UEFI:NTFS (make sure to toggle advanced options using the white arrow) -
Install Windows 8.1 into VHD using WinNTSetup 3.7.7
- Mount your Windows-ISO and choose “install.wim”
- Create VHD (fixed or dynamic, both work)
- Make sure that drive letters are correct
- Click “Setup” to install
I hope this is helpful to anyone. I’ll add some images later.
Here are some pictures for my post above (which I could not edit).
Let me know if this works for you ![]()
Can you please let me know how your system performance is when windows is installed like this ?
I have tried installing windows 2 go in different ways, but each time the flash drive performance dropped so much, it was almost unusable. After repartitioning/reformatting a few times, the drive became so sluggish it’s barely usable to copy anything on it, writing speeds are oscillating between 17KBps and 20-30MBps (copying large files, not booted from it).
When booting w2go there’s lots of microfreezes and lagging, not really usable as a working environment.
thank you very much in advance…
thanks for mentioning the performance issues. I have the exact same problem: At first writing speeds look ok but have sudden drops to almost 0. The more I use the device (without even running Windows To Go, just copying files) the slower it gets until it reaches a constant speed of <5 MB/s. However I’m not sure its W2G causing the performance drop - as I said I have just copied some large files. The only solution for me is to do a FULL format (NOT quick format) on the device. After that the writing speeds are around 180 MB/s again without any drops. I have no idea what is causing the slowdown and why a full format restores the original speeds - maybe someone from SanDisk could explain the behavior?
I searched more on the forums, and it seems there are quite a few people with this problem, with no response from Sandisk whatsoever. I opened a ticket to find out if there’s any development from Sandisk side on this issue.
Found a helpful postthat got me thinking about repartitioning and realigning partitions in the original configuration.
According to it, the original partition alignment is 32k, with the 1st cluster at 32k and formatted with 32k clusters.
All I managed using diskpart was to create an aligned partition at 32k and format it with 32k clusters, but didn’t find any way to align first cluster, which appears to be at 4k instead of the original 32k when I partition with diskpart.
After that I formatted to FAT32 with AOMEI Partition Wizard, since I couldn’t find anything else to let me format such a large partition with FAT32. HP USB format tool does format, but it repartitions too with other alignment, and I didn’t want that.
The result is that the flash is “almost” reset to the original performance, it writes at 190MBps (originally it wrote at 210MBps speeds). As soon as I reformat it to NTFS, the performance drops to an average of 2MBps, and severely oscillating, instead of writing continuously.
Still, I find it an immense PITA that there’s no way to format to NTFS without rendering it absolutely useless performance-wise, and I’m thinking of returning the drive, since there are other options that are close to that performance, less sensible to NTFS formatting and a lot more support.
If anyone has any idea, feel free to step in.
