Here are my specs
- Windows 7 pro
- Intel i5-2500K (overclocked to 4.0)
- 8 GB 1333 MHz Ram
- Gigabyte P67-UD4-B3 motherboard BIOS version F8
- Bios is set to AHCI mode
http://imageshack.us/f/171/atto.jpg/
http://imageshack.us/f/809/86722040.jpg/
“read is OK” but why “write” is so low?
Whats wrong? Is it hardware or software issue?
I think that board uses a Marvell SATA chipset. There are performance issues with Marvell SATA chipsets. If your SATA 6.0Gb ports are using a Marvell SATA chipset that is as fast as it is going to get.
yeah gigabyte use Marwell 88SE9128…
so there is no hope for me? should i buy new motherboard? or should i contact gigabyte support…
Nothing really wrong with those results. about correct for these drives in as-ssd.
Install the Intel Rapid storage drivers (I recommend version 11.1) and you will see a small increase.
