SanDisk Cruzer Glide 3.0
Description: This device is identified as a USB Mass Storage Device, specifically a SanDisk Cruzer Glide 3.0. It operates on the USB 3.00 protocol, supporting Super Speed with a maximum current of 896mA.
Device Information:
  • USB Device ID: VID = 0781 PID = 5597
  • Serial Number: 4C530001170525102524
  • Device Vendor: SanDisk
  • Device Name: Cruzer Glide 3.0
  • Device Revision: 0100
  • Manufacturer: SanDisk
  • Product Model: Cruzer Glide 3.0
  • Product Revision: 1.00
  • Controller Part-Number: Unknown
Additional Details: This SanDisk Cruzer Glide 3.0 is a high-capacity storage device with a capacity of 256GB. Despite comprehensive searches on the internet and contacting SanDisk directly, there is currently no available firmware information for this specific device. It’s noteworthy that the Controller Part-Number is reported as “Unknown” in the information obtained from ChipGenius v4.18.
If you have any recommendations or are aware of a reliable source for obtaining firmware for this device, your assistance would be greatly appreciated.
Thank you.
Hi @kurup3 ,
Flash drive companies generally don’t provide firmware updates for their drives. They’re too cheap a commodity for that to happen.
And Sandisk seems to want to hide their controller models. No transparency there. With my other models, I know exactly which controller they use.
