usb information
Description: USB Mass Storage Device(SanDisk Cruzer Blade)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 0781 PID = 5567
Serial Number: 200522434309F6B05D76
Device Vendor: SanDisk
Device Name: Cruzer Blade
Device Revision: 0102
Manufacturer: SanDisk
Product Model: Cruzer Blade
Product Revision: 1.10
Controller Part-Number: Unknown
There IS NO firmware for flash drives. What is it you are looking for and/or what is your problem?
usb flash not working .and not appear on the computer
Have you tried different USB ports and/or a different computer? If it’s unseen by different ports or computers, the drive may be defective; you should probably call SanDisk Tech Support about a possible warranty replacement.
Salam ALikom,
I have sanDisk flash drive 16 Giga, it does not read on my Dell laptop, but it reads on different computers,can i know why? is there update i could install or somthing?
did u manage to fix this i have the same problem
Max Current: 200mA
Serial Number: 4C532007371113105485
Device Revision: 0103
Product Revision: 1.20
I also need a firmware for my SanDisk Cruzer Blade. I inserted it in my defective hp laptop while downloading a software from
hp customer support and I made some error in the SanDisk firmware.
