Hi All,
I have 5 Sandisk Cruzer Force 32GB, I will be using them to deploy .bin image to my company’s PC.
I’m using imageUSB by Passmark, to create the image to USB from .bin file.
The problem is, after the process is done and the verification is completed, no files were written to the USB, what’s left is secureaccess v2 folder and the exe file.
What’s weird is, the first purchase, the first USB of same model, works, no problem. I was able to deploy the image to the PC without problem after the USB creation from same .bin.
The rest 4 USB won’t do the same, I suspect there is some kind protection that I don’t need is in the USB. Because the secureaccess v2 is keep coming back.
However, I was able to create a bootable Windows 7 installer into it, no problem. I was using Rufus for this.
Is there anyone out there, ever encountered this? I need help.
Thanks in advance.
