Samsung micro SD card
OK I take them out the folder have them in & put them in the music folder & what about this it keeps telling me there is a new firmware update available for the player do I update that or don’t worry about it
I still need to know what to do for the firmware update for the player do I update or do I not update
Personally, I would uninstall the Updater and not worry about it. It’s nothing but bloat and nag-ware. And I still have the .15 firmware version on my clip+ that works just fine and dandy. The last few ‘updates’ have had very minor adjustments, with no new features or major bug fixes.
OK thanks I do that
how do you make a Playlist using the Rockbox SanDisk Sansa Clip+
Have you read, or consulted the Rockbox manual?
Page 34 to be precise.
I did read the manual but it was not much to explain in simple terms on how to do it
I tried to sing up on the Rockbox forums but the Verification I have to answer I don’t understand what is asking for it says this: What is 5+8?( Enter banana in the field) & it doesn’t accept anything I put in as the answer do you have an idea of what they are asking for
lol
Have you tried just entering the word banana?
I just finally tried that & it worked
I have but so far nobody has answered they have just looked at it
