Resume audiobook and resume podcast menu choices
“I want to listen to my book without losing my place but sometimes flip over and listen to music”
That is a problem that I ran into. If the books or podcasts are properly tagged, and played from the audibook or podcast submenu, then the player will remember which audiobook or podcast file was playing last after you play some music files and turn off the player. If the books or podcasts aren’t tagged though, and you are playing them through folder mode, then it won’t remember which audiobook file was playing last(and to restore the browsing by folder mode) if you play some music then turn the player off. I wish Sandisk would fix this. A resume audiobook and a resume podcast menu choice(when pressing the button at 6 oclock from any mode) could restore the play mode and the file playing and place in the file when an audiobook file or podcast file was last played.
Message Edited by JK98 on 09-25-2009 10:18 AM
It would also be nice to have a resume music menu choice when playing a podcast or an audiobook. These menu choices would make it easy to switch from a podcast or audiobook to music then back at any time, without losing the place, even for untagged files that are being played in folder mode.
Message Edited by JK98 on 09-23-2009 01:24 PM
No comments?
It would also be nice to have a mark next to each podcast in the podcast list that has been completely listened to, and a different mark for those that have been partially listened to. This could be done for audiobook files as well.
No comments? Anyone else find it hard to use a player for both podcasts and music? I don’t want to have to tag the podcasts, as they are often listened to once then removed from the player.
A delete read podcasts function on the player would be nice, which would delete all the podcasts that have been completely listened to on the player with just one instruction.
It would be great if Sandisk could fix this. If they are reading this… please!
