Hello, for some reason, each song plays twice in a row…??? I have tried deleating the files, and re-loading them, but it still does it. Any ideas?
Thanks so much
Thanks so much
Where are your songs coming from and how do you transfer the songs? I would like to suggest to format your device by connecting it to your computer and do a right click and on your device and choose the option format, and let us try to transfer the songs again.
Hope this works.
Nope, didn’t work. Thanks for trying.
figured it out, I had the repeat button on!!! duh
Aha, I did not think of that I thought the songs are playing continously twice in a row, its a good thing it is ok now. ![]()
