I’m trying to rename the drive and getting the error message “Try using a name with fewer characters or with no punctuation marks.” my other hard drives allowed me to name them with the name ‘DWS External Hard Drive’ without any issues. Normally this would not bother me but I have some adobe programs that point all the links to this path name and without it being the same it is going to create days of work relinking everything.
Any help in being able to make this work would be helpful.
If you’re experiencing renaming issues with a portable SSD, it could be due to file system limitations or compatibility issues. Ensure the SSD is formatted properly and consider using a compatible file system such as exFAT to avoid renaming problems. SanDisk Extreme SSD Failure: Tips to Prevent from Further Damage
Luckily with EaseUS Recovery I got it all back but I want to stay with Sandisk.
