can you add a toggle to remove the annoying notification about dashboard is running in the system tray please, i don’t see any use for it other than annoying the user everytime they close the app to the system tray, images:
To stop the “Dashboard is running” notification, check the app settings to turn off notifications or running in the background. If there’s no option, go to Windows Notifications settings and turn off notifications for the app. You can also disable “close to tray” if available.
That’s the issue i only want that notification disabled and i need dashboard running to update me about the ssd health.
This is strange, it always worked for me.
