Hello- I am getting popups in the taskbar notification tray when I close the SSD Dashboard. It is telling me to click the SSD icon to open the Dashboard again. I have to click the “X” in the balloon popup to remove the popup and sometimes it will come up several times if I do not open the Dashboard. How is it possible to disable the balloon popup?
I am using a personal computer with Windows Vista operating system.
in that case i would suggest closing the whole software and not let it run with windows all the time since it is not required. so you can open the software once per week to check the status of the ssd and then close it again.
i do not think there is a way to disable to pop ups
